BRAKE LIGHT ON PASSENGER SIDE DOES NOT WORK ALL OTHERS DO CHANGED BULB AND CHECKED GROUND WIRE
Mar 18, 2009 at 9:30 AM
✓Experienced Mechanic
Check rear right turn signal fuse no. 16 10amp this fuse powers both the right rear brake/turn signal on the back. If fuse is okay have the multifunction switch tested
