Our database doesn't give bolt by bolt procedure. It's generic, take negative battery cable loose, remove belt, take wiring connnectors loose from alternator, remove alternator mounting bolts, remove alternator.
Anytime you remove battery voltage from computer, when you run engine again, there may be some relearn issues. Sometimes, it will relearn by itself.
Friday, February 26th, 2010 AT 11:13 AM
