1998 Chevy S-10
1998 CHEVROLET S-10
98,000 MILES • 4 CYL • 2WD • AUTOMATIC
FAIRLANE56
I hit a bump, since then truck willl not start. Replaced Crank Shaft sensor, had Ingition Modular tested. that comes back good. All fuses are good. Still won't start. I have 1/2 tank of gas and yet the gas gauge registers "E". What else should I look for? HELP! This is my only means of transportation.
Feb 14, 2010 at 1:16 AM
JDL
  • 16,098 POSTS
Welcome to the forum. If your saying it cranks good but won't start, did you visually check for spark at the plugs? You can pull a plug wire, stick known good plug in the boot, ground metal part of plug to metal part of engine, look for a spark, engine cranking. Use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage.
Feb 14, 2010 at 2:23 AM
