HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
S-10
Engine Cooling
Thermostat
1998 Chevy S-10
EDHOELZER
MEMBER
1998 CHEVROLET S-10
4 CYL
2WD
AUTOMATIC
118,000 MILES
How to replace thermostat
Sunday, February 24th, 2008 AT 6:54 AM
2CARPRO JACK
MECHANIC
Follow the hoses to the engine, one wil have an outlet held on by 2 bolts. Let engine cool, drain coolant, remove hose, tehn unbolt the housing, t-stat is under it. Clean all mating surfaces good and use anew seal and reverse to assemble
SPONSORED LINKS
Saturday, October 3rd, 2020 AT 11:42 AM
Please
login
or
register
to post a reply.
Related Thermostat Content
Thermostat Change
If I Change The Thermostat In My 1998 Chevrolet S-10, With A 4.3 Engine, From A 195 Degree To A 180 Degree, Will There Ne Any Negative...
Asked by
roygossett
1 ANSWER
1998
CHEVROLET S-10
VIDEO
Thermostat Replacement Chevrolet Blazer
Instructional repair video
GUIDE
Thermostat
The thermostat is located on the engine either at the inlet or outlet radiator hose connections and is part of the cooling system, this unit is designed to stop the flow of...
Thermostat?
My Truck Runs Well, But When I Sit At A Stop Light For An Extended Period Of Time Or Go Thru The Drive Thru My Engine Temp Goes Up.A Lot....
Asked by
cjsiefken
1998
CHEVROLET S-10
Thermostat Replacement?
Coolant Seems To Be Coming From Behind Plate Behind Fan Clutch. Is There A Gasket Behind There? It Is A 2.2. The Water Pump Is To The Right...
Asked by
Chipdealer
1998
CHEVROLET S-10
1998 S-10 2.2 Engine Not Warming Up To Temp. Done...
Only Getting Up To 140
Asked by
Camsaltsman
1 ANSWER
1998
CHEVROLET S-10
Within The Last Thirty Days, I Have Had Intermittant Problems With The Truck Starting. I May Get In And It Won''''t Start...
Asked by
chevydogs
8 IMAGES
2001
CHEVROLET S-10
VIEW MORE
SPONSORED LINKS
How to Replace Thermostat
Thermostat Replacement Chrysler
Thermostat Replacement Dodge
Online car repair manuals
