1997 Chevy S-10 wiring problems
JAMES B
Electrical problem
1997 Chevy S-10 6 cyl Four Wheel Drive Manual
on my truck i have taillights and turnsignals but no brakelights or reverselights.
Feb 19, 2009 at 2:04 AM
JDL
  • 16,098 POSTS
Hello, the back-up switch should be located in the trans housing, the pink wire goes hot when you turn on the key, the lt green wire goes hot in reverse.
Does the high mount brake lite work ok? The lower brake lites are wired through the turn switch, but, there is a relay. I'd check the proper fuses and fuse circuit for voltage.
Feb 19, 2009 at 2:52 AM
