1997 Chevy S-10 turn signals
202,400 MILES • 4 CYL • 2WD • MANUAL
TREESEOU
The turn signals are not operating, however, the hazards are working. Is this a short or a blown fuse?
Aug 5, 2010 at 4:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
You will first want to check fuse #16 (15 amp, may be labeled TURN B/U) in the fuse box. If OK then the turn signal flasher may be at fault. The hazards use a separate fuse and separate flasher unit.
Aug 5, 2010 at 7:37 PM
