The turn signals are not operating, however, the hazards are working. Is this a short or a blown fuse?
Thursday, August 5th, 2010 AT 11:34 PM
BLUELIGHTNIN6
MECHANIC
Hello and thanks for donating
You will first want to check fuse #16 (15 amp, may be labeled TURN B/U) in the fuse box. If OK then the turn signal flasher may be at fault. The hazards use a separate fuse and separate flasher unit.
