I changed my starter and nothing.Battery is good.I turn the key and dash lights come on but nothing else happens...doesnt even try to turn over.
Apr 11, 2010 at 6:23 AM
INTERNETMECHANIC
✓Experienced Mechanic
Check the circuits at the starter relay, under the hood. Terminal 30 is hot all the time. Terminal 85 goes hot with the key in the crank position, that circuit is wired through the clutch switch. Any testing, make sure the tranny is in neutral and functional e-brake is set.
