1997 Chevy S-10 Squeeking sound
25,000 MILES • 6 CYL • 2WD • AUTOMATIC
VAMIAN
There's a squeeking sound somewhere in the back of my truck and as I accellerate the squeeks go faster. After couple of minutes, it'll go away. I noticed this only happens in the morning or when when the car haven't been running for more than 2 hrs. I put the truck on jackstands and supported the rear axle on a floor jack and put it in drive and no squeeks found. Previous owner removed 1 leaf spring on both sides, would that have to do with the noise? I'm still guessing its on the driveshaft or rear differntial. Thank you for your help.
Jul 29, 2010 at 6:44 AM
DOCFIXIT
  • 18,828 POSTS
Is parking brake set for overnight?
Jul 29, 2010 at 8:36 AM
VAMIAN
No parking brake set. I noticed it's alot louder going up a steep road or a heavy load on the bed of the truck when the car is still cold.
Jul 30, 2010 at 4:38 AM
DOCFIXIT
  • 18,828 POSTS
Possible brakes making noise have you pulled drums see if the shoes are glazed or build up of brake dust
Jul 30, 2010 at 4:43 AM
VAMIAN
No I have not. i'll try that but the tweety bird noise rotation is faster than the wheel. It sounds in sync with the rotation of the driveshaft.
Jul 30, 2010 at 5:05 AM
DOCFIXIT
  • 18,828 POSTS
Maybe dry U joints needle bearings could be chirping. When you jacked up to listen took load off so no chirp
Jul 30, 2010 at 5:46 AM
