1997 Chevy S-10 PCM
1997 CHEVROLET S-10
ERICDE
  • 8 POSTS
Computer problem
1997 Chevy S-10 4 cyl Two Wheel Drive Manual 300k miles
I recently replaced a leaky fuel injector, since then my truck has an oddly erratic idle. A small 1-200 rpm bounce every second, barely noticeable, I didnt notice it, but the smog guy did when the service engine soon light came on in the middle of the test, so he wouldn't pass it. So I read a little on the Idle Control Valve and how when disconnected the PCM has to relearn the correct idle. Is there a procedure i need to imply or should it relearn on its own. would that even contribute to an rpm surge?
Jun 29, 2010 at 12:35 PM
Could be an idle relearning problem fast way to do it is use a Tech1 scantool or just clean out the idle air control valve and see what happens
Jun 29, 2010 at 9:35 PM
