1997 Chevy S-10 no fuel to engine
BREIDL
  • 1997 CHEVROLET S-10
  • 6 CYL
  • MANUAL
  • 110,000 MILES
I have a 1997 chevy s-10 with a 4.3 vortec v6 when I was driving it the other day it went died on me with no warning at all. I replaced the filter replaced the distributor cap and rotor it has spark and I can get it to run with a little bit of fuel from the TB. The fuel pump seems to be working well I can here it running. I have not been able to look at the injectors. I have taking the power cable off to reset the pcm what else could be causeing me not to get fuel.
Wednesday, March 10th, 2010 AT 6:40 PM
BLACKOP555
  • 10,371 POSTS
Bad fuel injector fuse. You may be getting the pump turning on. But is it pumping enough. There is a filter on the fuel pump in the tank, and pumps do go out.
Best bet is to check the fuel pressure.
Thursday, March 11th, 2010 AT 9:00 AM
