1997 Chevy S-10 need help
170,000 MILES • V8 • 4WD • AUTOMATIC
BOGIE7558
I cannot keep pressure. no leaks, abs is unhooked. I have to pump to get pressure. then to the floor. any ideas ? what am I missing ? brakes are usually pretty simple, but this ones got me.
Mar 9, 2009 at 2:49 PM
FRANK2009
  • 10 POSTS
I would check my master cylinder.
It has 2 parts one for the front and the 2en for the back
if u r holding on the brake and it keeps going down and builds when u pump it up. One of ruber seals could be bad and letting the fluid bleed off.
Dirt and rust in the master cylinder will cause this.
If u think this is what it is and u r game to try u could take it apart and give it a good cleaning.
I've done this a number of time and it has worked.
Hope this is some help
Mar 11, 2009 at 10:57 PM
