1997 Chevy S-10 Leaks oil
106,000 MILES • 4 CYL • 2WD • AUTOMATIC
MSCHWARTZ
It leaks oil but Im not sure where its coming from.
Jun 3, 2010 at 6:30 AM
BLACKOP555
  • 10,386 POSTS
you have two options. you can buy some flurecent dye and a blacklight used for testing it and put the dye in the oil and run the vehicle then use blacklight and look for leak. or you can take a pressure washer. clean all the old oil off and spray baby powder on it and run it. youll see where the leak is coming from on the baby powder right away
Jun 4, 2010 at 12:00 PM
