1997 Chevy S-10 Headlights keep going from dim to bright on
1997 CHEVROLET S-10
SKATEKING5000
Electrical problem
1997 Chevy S-10 4 cyl
My headlights when turned on bright will flicker on and off on their own, and when they do i hear a clicking noise over in the relay access in the glove department. I tried replacing one of the relay fuses but it did no good. There are only 3 fuses and they are the big black 5 prong ones. I havent checked any more fuses because of the noise coming from the relay access. What is the cause of this problem and whats its solution? Thanks alot.
Oct 4, 2010 at 5:59 PM
Have the alternator load tested and check the charging system wiring to include the headlamp switch
Oct 4, 2010 at 10:34 PM
