1997 Chevy S-10 Headlight, brakelight and turn signal probl
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
RIGGT
When you step on the brake pedal. Ignition off, the door chime sounds.
-4ways alone make dash lights blink.
-All turn signal bulbs pulled, Left turn on, the headlights will blink slightly.
-Headlights on,Key off,Left turn trys to flash all turn signals. Left side brake light is on.
-4ways work until you turn headlights on then they freeze on.
-Brake lights always on with headlights.
-Wipers work on hi only. wont park
-The 2 signals on the right front blink together instead of alternating. Left triangle amber doesn`t blink at all.
I installed a new turn signal switch and still had all the same symptoms so I took it back.. Polease Help!!!!!!!!!!!
5 minutes after I sent the donation I wentback out to the garage and found the problem !
If ya cancel me 10 donaton I cold tell ya solution!
Just kidding, It was the junction connector in the tail light wiring that splits out to the trailer plug I never use. I removed it and plugged the ends together and problem solved! Lessoned learned. Maybe it will help someone in the future. Thats what its all about anyways. Trigg
Mar 13, 2009 at 9:18 AM
RACEFAN966
  • 5,029 POSTS
Yea when those trail plug connectors get corroded they will do that and man can they cause havic sometimes too.
Mar 13, 2009 at 2:10 PM
