1997 Chevy S-10 head gasket
ABIGTONY38
Engine Mechanical problem
1997 Chevy S-10 4 cyl Two Wheel Drive Automatic 107.00 miles
how do i adjust the rocker arms,,, and what is the tourqe ft lbs i should use and the correct pattern. and help would be great
Jun 30, 2010 at 10:25 AM
BLUELIGHTNIN6
  • 16,542 POSTS
rocker arms with press in studs , stud tighten to 35 ft. lbs. and nut to 18 ft. lbs.
rocker arms with screw in studs, stud tighten to 35 ft. lbs. and nut to 19 ft. lbs.
hydraulic lifters are used , an adjustment is not needed
Jun 30, 2010 at 10:47 AM
