The clutch fluid hose would have to be replaced, but you should check on theparts first, some of those S-10 clutch lines came with the clutch master cylinder attached, you couldnt get them seperatly. Other than that, you simply replace the line and bleed the system. As far as the ABS goes, you will need to have thesystem scanned for the codes it is storing to see why it is turning on the light. There are far too many things to just guess at what it may be
SPONSORED LINKS
Wednesday, April 21st, 2010 AT 7:47 AM
