1997 Chevy S-10 diagram S10
1997 CHEVROLET S-10
D_SKALEY
Engine Mechanical problem
1997 Chevy S-10 Two Wheel Drive
I would like to find a diagram of where the oil drain plug is on a 1997 Chev S10?
Oct 11, 2008 at 5:05 AM
SWILLIAMS
  • 597 POSTS
Easy to find. Jack up or drive onto ramps. Block vehicle in position. Slide under the truck. Look at the oil pan. Drain plug will be very obvious. It is the only item in the bottom of the pan. Oil filter will be on the drivers side of the engine.
Oct 11, 2008 at 10:18 AM
D_SKALEY
Thank you
Oct 11, 2008 at 11:34 AM
