1997 Chevy S-10 cranks but does't start
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
ZEKE RENNIE
When the ignition switch is turned to the run (not start) position the dash lights don't come on to indicate to me that all systems are go. If I turn the key to the start position the motor cranks but won't
start. This does'nt happen all the time but with greater frequency lately. Also, once in a while the engine will die and dash lights go out while running at low speeds. The engine otherwise runs good.
Dec 28, 2009 at 4:46 AM
  • 75,988 POSTS
Have your ignition switch check and tested
Dec 28, 2009 at 5:41 AM
