1997 Chevy S-10 cooling fan clutch
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
ROBERTYOST
how do you remove???
Jun 9, 2010 at 1:16 AM
HMAC300
  • 48,601 POSTS
if this has the large nut on the front of the water pump you need to take that off then unbolt the fan. If it's not, then you need to unoblt the 4 bolts that hold the assembly to the waterpump pulley. then take that off with the fan and remove the fan from the fan clutch. then reverse to assenble.
Jun 9, 2010 at 7:54 AM
