1997 Chevy S-10 Clutch slave or Master Cylinder
1997 CHEVROLET S-10
148,889 MILES • 4 CYL • 2WD • MANUAL
PRIMUS77
the clutch petal has no resistance to it and cannot shift gears while engine is on. I've disconnected the line and still no resistance, fluid levels good. need to know if its the slave or master before i remove parts.
Dec 6, 2009 at 4:46 PM
HMAC300
  • 48,601 POSTS
if i'm not mistaken the slave and master come as an assembly. So you can't replace one without the other....
Dec 7, 2009 at 3:55 AM
