1997 Chevy S-10 clutch slave cylinder assembley
268,000 MILES • 4 CYL • 2WD • MANUAL
DANIEL YARBROUGH
My hydraulic line resease cylinder is leaking inside the transmission bellhousing. My manual says I will need to remove the transmission to replace the release cylinder and or the seal. Is there another way,and what if any special tool (s) will I need. Thanks to anyone who can help me !
Jan 26, 2010 at 7:08 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you will need a hyrdraulic clutch line separator tool and yes you must remove the transmission to replace the slave cylinder.
Jan 26, 2010 at 8:22 AM
