1997 Chevy S-10 brake light
166,008 MILES • 4 CYL • 2WD • MANUAL
QUADRIDER60
when i lightly push on my brake peddle the lights come on but if i push harder they go out but then they do not work at all. the tail lights and the turn signals work fine all of the time and i do belive the brake light and turn signal are the same bulb. thank you
Feb 15, 2009 at 10:56 AM
BLUELIGHTNIN6
  • 16,542 POSTS
need to inspect your brake light switch, mounted on top of brake pedal. suspect that it is out of adjustment or needs replacing.
Thanks for using 2CarPros.com!
Feb 15, 2009 at 11:11 AM
  • 75,988 POSTS
Check the brake switch sounds like its defective if its doing that.
QUADRIDER60
thank you thats what i thought it was
Feb 19, 2009 at 4:28 AM
