1997 Chevy S-10 BRAKE GRAB AND GRIND
60,000 MILES • 4 CYL • 2WD • MANUAL
STAN1462
WHEN I AM BRAKING AT A LOW SPEED, AROUND 20 MPH, THE BRAKES WILL GRAB, KIND OF SPUTTER. THEY FEEL LIKE THEY MIGHT FAIL, BUT DON'T - I CAN PRESS HARDER ON THE PEDAL AND THEY SEEM TO TIGHTEN DOWN. THEY ALSO MAKE A HIGH PITCHED GRINDING SOUND, BUT THE PADS ARE NOT DAMAGED OR WORN. I'VE HAD A COUPLE OF MECHANICS CHECK, WITH NO LUCK.
ANY GUESSES.
STAN SCROGGINS
May 16, 2009 at 8:22 AM
MERLIN2021
  • 17,250 POSTS
Is the pedal low? hard? soft? Any lights on?
May 17, 2009 at 12:12 AM
HEMPCAVER
My truck is doing about the same thing... how ever did you fix it???!???!???
Jun 9, 2009 at 4:28 AM
MERLIN2021
  • 17,250 POSTS
https://images.2carpros.com/forum/automotive_pictures/62217_s10_Brakes_1.jpg
This is a Tech bulliten on caliper and or steering knuckle wear, and measurements. Check yours to see if it's in spec.
Jun 9, 2009 at 7:34 AM
