1997 Chevy S-10 Acts like not getting fuel
WEEIGI
Engine Mechanical problem
1997 Chevy S-10 6 cyl Two Wheel Drive Automatic
Just replaced the fuel pump in gas tank now I am thinking that fuel pump burnt up because fuel regulator
it not working need to see a diagram of this area bof the engine new pump is working and there is gas in the lines in the engine but truck still won't stay running.
Jul 31, 2010 at 11:22 AM
  • 75,988 POSTS
Check the fuel pressure if its within specs if okay clean out the idle air control valve and EGR valve and test t he throttle position sensor and manifold absolute pressure sensor.
Jul 31, 2010 at 12:04 PM
