1997 Chevy S-10 Acts like not getting fuel
WEEIGI
  • 1997 CHEVROLET S-10
Engine Mechanical problem
1997 Chevy S-10 6 cyl Two Wheel Drive Automatic
Just replaced the fuel pump in gas tank now I am thinking that fuel pump burnt up because fuel regulator
it not working need to see a diagram of this area bof the engine new pump is working and there is gas in the lines in the engine but truck still won't stay running.
Saturday, July 31st, 2010 AT 6:22 PM
Check the fuel pressure if its within specs if okay clean out the idle air control valve and EGR valve and test t he throttle position sensor and manifold absolute pressure sensor.
Saturday, July 31st, 2010 AT 7:04 PM
