1997 Chevy S-10 ac pulley replacement
130,000 MILES • 4 CYL • 2WD • MANUAL
JOSH613
I have a A/c replacement pully. It does nothing but turn. Like a fake pulley. How does that mount on? And what do i do with the freeon piping?
Feb 21, 2010 at 7:29 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you mean you are bypassing your vehicle's A/C , correct? if so then remove the a/c pump pulley assembly and mount bypass pulley in its spot. you can leave the a/c plumbing unless you just want to remove it.
Feb 21, 2010 at 11:57 AM
