1997 Chevy S-10 abs light stays on
52,000 MILES • 6 CYL • 2WD • MANUAL
DANR12386
I changed a brake line to the passenger side wheel. now the abs light stays on. it first turned on when the line broke. i blead the brakes and it still stays on is there any way to reset the light.
Mar 13, 2009 at 12:36 AM
  • 75,988 POSTS
CLEARING DTCS
A DTC set in a current ignition cycle will not clear during that same ignition cycle. Cycle ignition switch off for 10 seconds and then on to clear a DTC set in current ignition cycle. If ANTI-LOCK light is staying on, DTCs can be cleared with a scan tool.
Mar 13, 2009 at 12:52 AM
