1997 Chevy S-10
KACKDOG
Engine Performance problem
1997 Chevy S-10 4 cyl Two Wheel Drive Manual
Have this 97 s 10 with 2.2 will not start. Have good fuel presure, injectors pulsing, Replaced crank sensor, Replaced fuel regulator, swapped out computers, spark on all cylinders, and will run for few second if squirt fuel in throttle body. What else is there? Has to be a fuel problem but what?
May 20, 2010 at 6:10 AM
  • 75,988 POSTS
Could be the fuel pump relay or the computer controlled of the fuel pump relay.
May 20, 2010 at 9:05 AM
