1996 Chevy S-10 Water Pump Leaking
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
ORE1957
I have a leak that looks to be coming from the upper back of the water pump. This is my 1st S10 V6 and the water pump appear to be mounted onto a plate and the water spraying from below a bolt. Is the mount of a pump different on this type of vehicle and perhaps not a bad water pump? Pleas help?
I cannot insert a picture until morning.
Thank you,
Oscar
Mar 25, 2010 at 2:01 PM
BLUELIGHTNIN6
  • 16,542 POSTS
nothing special here, if coolant is leaking near water pump then it is most likely either a failing water pump, coolant hose or a failed water pump gasket.
Mar 25, 2010 at 2:29 PM
