1996 Chevy S-10 stop lights stay on
JAMESLATHROP
Electrical problem
1996 Chevy S-10 4 cyl Two Wheel Drive Manual
I have replaced all the bulbs and the brake pedal switch and the brake lights still stay on , so I have to pull the fuse and run with no brake lights . any ideas? Thanks James
Nov 29, 2009 at 2:22 PM
  • 31,937 POSTS
HI there, with the brake switch fitted, is it adjusted correctly, with the brakes off is there still power through the switch?
Mark (mhpautos)
Nov 29, 2009 at 2:47 PM
JAMESLATHROP
I took the brake switch off the pedal and manually push in the contact and the brakes still would not shut off. do you think I may have a grounded wire somewhere? thanks James
Nov 30, 2009 at 11:05 AM
  • 31,937 POSTS
Hi there,
did you check for voltage running through the switch all the time, it may be a faulty new switch this does happen.
Mark
Nov 30, 2009 at 11:10 AM
