1996 Chevy S-10 S10 Coolant Fan removal
169,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHRISTIND
Please I am trying to remove the coolant fan so I can replace the waterpump on the s10. I have already removed the radiator.
Thank You kindly for your answer
Apr 15, 2010 at 6:13 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove the upper radiator shroud and, if desired for additional clearance, remove the radiator from the vehicle.
Remove the fan assembly attaching nuts, then remove the fan assembly from the engine.
If necessary, the clutch may be removed from the fan by removing the attaching nuts or bolts (as applicable).
Apr 15, 2010 at 7:01 AM
