3" hole in the transmission bell housing?
118,000 MILES • 6 CYL • 4WD • AUTOMATIC
ANOOBIS
Hi there. Not sure if the form will show it all so I'll just put the info here too:
1996 Chevrolet S-10
118000 miles
4.3 L HO V6
4WD
Automatic Transmission
Been a solid truck since I've owned it for the last 8 years.
I was changing the oil last weekend when I noticed what looks like a 3" hole in the transmission bell housing. I could see the flywheel. I suspect it is some sort of maintenance hole. Is there something I can get to cover it back up?
Thanks
Dec 12, 2007 at 2:37 PM
DDJRKH
hi, there is a metal cap that fits in that hole. you should have a smallerone almost next to it. you can order them from your chev. dealer
ddjrkh
Feb 11, 2008 at 11:43 AM
  • 55,676 POSTS
Yep, that is an inspection hole, they make covers for it but you can use a plastic one as well which you can get from amazon.
Sep 7, 2024 at 1:34 AM
