1996 Chevy S-10 Oil pump problem??
149,000 MILES • 4 CYL • 2WD • AUTOMATIC
EWHIT
  • 10 POSTS
I was driving down the parkway and suddenly my engine started losing power. My oil pressure gauge went to zero and flucuated at zero and slightly above. I pulled over to the side of the road thinking i was out of oil but it was full. I got back in my truck and continued to drive down the road. I could barely get my truck up to fifty or sixty and the engine kept revving up and the transmission kept shifting. When i stopped at a garage there was a knocking noise in my engine. Three days later i had it towed home and when i started it the oil pressure gauge was halfway and there was no knocking noise. What could cause this?
Mar 15, 2010 at 6:09 AM
HMAC300
  • 48,601 POSTS
fromwhat you describe, it kind of sounds like you may have done some damage to the internals of the engine. The best thing to do is put a mechanical guage on the engine and see if you get better pressure as it could be a sending unit, but don't get your hopes up. The knocking noise may have been your lifters getting low on oil andthen when they got the oil they quit knocking or ticking. So try a mechanical guage first and see what you get if it's jsut as bad as the dash then have a pro look at it.
Mar 15, 2010 at 12:32 PM
EWHIT
  • 10 POSTS
Thanks. I'm having someone look at it today. I don't know if it makes a difference or not but my cruise control quit working less than a minute before all this happened. It completly quit working at first then would come on then go back off. I looked at it again last night but the knocking is definatly still there i just didn't hear it the other day.
Mar 16, 2010 at 2:26 AM
