Engine Mechanical problem
1982 Chevy S-10 6 cyl Two Wheel Drive Manual
Hi I have a 82 ,S-10 with a 2.8 motor. I am think of fixing up another 2.8 motor to put in the truck in the future. It seams the lower main bearing are a weak spot in the 2.8 motors. Would you recommend putting a high Out- Put oil pump into it? Thanks Darrell
Nov 17, 2008 at 2:30 PM
