1996 Chevy S-10 oil pan gasket
DHVCABS
Engine Mechanical problem
1996 Chevy S-10 4 cyl Two Wheel Drive Manual
how do I get the oil pan off? Removed everything in the way (starter, etc) but I still can't get it to drop. Help!
Mar 24, 2009 at 10:02 AM
EUGENE123
  • 273 POSTS
take a second look at everything around the oil pan if you are 100% sure everything is out of the way get a flashlight of somekind and look at the oil pan bolts. you may think you have took them all loose but some of them are hidden and hard to see. If your still having trouble post back and i will help you further with this problem
Mar 27, 2009 at 3:26 AM
