1996 Chevy S-10 no fuel
RAZEY
  • 1996 CHEVROLET S-10
1996 Chevy S-10 6 cyl Two Wheel Drive Manual
still no power to my fuel pump. Iput in new relay and checked the fuse. What else can I do?
Saturday, July 17th, 2010 AT 12:20 PM
Check the gray wire if its open between the fuel pump and fuel pump relay
Saturday, July 17th, 2010 AT 2:22 PM
T_SMIGIELSKI
As in chiltons manual there is a red wire under hood drivers side back by the hinge with no connector attached to it. Run a jump wire to it directly from + post of battery, have key on + you will hear the pump run. Had the same problem myself last week.
Tuesday, July 20th, 2010 AT 9:28 AM
