1996 chevy s-10 LS
SELENA DOMINGUEZ
I really need to know where the turn signal unit is located... i've tried locating it behind the glove box but was unsuccessful at removing it... there's supposed to be a sping that you push upward on and it should release the door??? , i didn't find it... then it could also be behind the knee bolster... again i was unsuccessful at the removal of it... so if you know exactly how to get to to the turn signal unit PLEASE will you help me out?!?!?!?!?!
Jul 22, 2007 at 9:10 AM
SELENA DOMINGUEZ
[quote:2aa30700e8="techman1"][quote:2aa30700e8="Selena Dominguez"]I really need to know where the turn signal unit is located... i've tried locating it behind the glove box but was unsuccessful at removing it... there's supposed to be a sping that you push upward on and it should release the door??? , i didn't find it... then it could also be behind the knee bolster... again i was unsuccessful at the removal of it... so if you know exactly how to get to to the turn signal unit PLEASE will you help me out?!?!?!?!?![/quote:2aa30700e8]
I would check bulb sockets, grounds for them, and the turn signal switch on the steering column before I would figure that the turn signal flasher failed.[/quote:2aa30700e8]
thanks so much for the reply but i got it taken care of...
Jul 25, 2007 at 8:35 AM
