1996 Chevy S-10 how to install the lower control
PANTERA310
  • 1996 CHEVROLET S-10
Suspension problem
1996 Chevy S-10 6 cyl Four Wheel Drive Automatic
I got a problem with the big bars
Tuesday, January 13th, 2009 AT 8:59 PM
DE772601
  • 123 POSTS
Hi
To help you out your going to have to take the pressure off the torsion bar to loosen it there is a bolt in the back by the transfer case, once that is loose then you will have to drive the torsion bar out of the lower control arm. Just repeat the process putting it back in again. I hope this will help you out.
Thursday, January 15th, 2009 AT 9:45 PM
