1996 Chevy S-10 Heating
SUPERTEN96
Heater problem
1996 Chevy S-10 4 cyl Two Wheel Drive Manual
Replaced the thermostat, the coolant is filled and it is still heating over 210 and the heat is not nearly as hot?
Oct 31, 2010 at 8:32 AM
  • 75,988 POSTS
Check if the radiator is clogged and water pump doing its job if both okay -try bleeding the cooling system-don't work-get it block and pressure tested.
Oct 31, 2010 at 10:38 AM
