1996 Chevy S-10 heat
117,000 MILES • 6 CYL • 2WD • AUTOMATIC
DEADHEAD4LIFE1
this truck has no heat i replaced the thermostat and gasket also the radiator cap and replaced all the anti freeze the truck tempature rises up to around 210 degrees but does not produce any heat out of the heater vents at all any info would be a big help its been to cold to drive but still have to work
Jan 16, 2009 at 7:22 AM
TERESAHEN1958
[quote:fe24644c67="deadhead4life1"]Heater problem
1996 Chevy S-10 6 cyl Two Wheel Drive Automatic 117000 miles
this truck has no heat i replaced the thermostat and gasket also the radiator cap and replaced all the anti freeze the truck tempature rises up to around 210 degrees but does not produce any heat out of the heater vents at all any info would be a big help its been to cold to drive but still have to work[/quote:fe24644c67]maybe the heater core
Feb 5, 2009 at 10:53 AM
FEESH13937
  • 12 POSTS
i had the same problem on my 2001 s10. as long as there are no antifreeze leaks any where such as chocolate milk oil on the dipstick, antifreeze on the ground and so on, then you should try reverse flushing the heater core. Not to hard to do. take the the two heater hoses that run into the fire wall on the passenger side of the truck off. One is an inlet and the other an outlet. take a garden hose with a nozel with a jet setting on it and hold it up to one of the holes of the heater core. does not matter witch one first as you will do this to both holes. hold the water pressure for about 2 min. or so and the water should come out the other hole. you will heare a girggle sound. take the hose off and put it in the other hole on the opposite side of the one you just shot water into. hold about 2 min. and the heater core should be cleanded out. this should fix ya right up and you should have burn ya out of the truck heat. Good luck. as long as there is no antifeeze leaking out anywhere then this should do it. if there is antifreeze leaking on the ground prior to this method then the heater core may be shot. let me know what you find out. feesh13937@yahoo.com
title the email, no heat s10 so i dont spam the e-mail
Feb 11, 2009 at 5:06 PM
