1996 Chevy S-10 FUEL PRESSURES
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
DREAMER435
i just replaced the fuel pump and fuel filter and the engine seems to have a steady miss, like its getting enough fuel. can you tell me what pressure i should have at idle and full thottle?should the pump hold the pressure when shut down?
THANKS
Jul 12, 2008 at 7:26 AM
DOCFIXIT
  • 18,828 POSTS
48 to 52 psi and should hold pressure after shut down. If not leaking injectors.
Have you gone through ignition and checked for vaccum leaks. Also any DTC's-
Jul 12, 2008 at 8:00 AM
