How do you remove the fan clutch assembly from the water pump.I have taken the 4 bolts off the pulley, but the fan assembly want seperate.
Apr 6, 2009 at 4:00 PM
2CARPRO JACK
✓Experienced Mechanic
Does it have one big nut on the end of the fan clutch? If so you will need the correct wrench to remove it while holding onto the pullley.It is 2 wrench's one for pulley one for clutch.If it doesnt have one big nut you need to wiggle it back and forth to get it to come off the end of the water pump, tight fit but it will come off
