1996 Chevy S-10 Distributor
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
WWSIMMS
No spark to spark plugs, engine will not run but turns over. Checked the coil and it seems to be sparking! What is the exact problem with this frustrating problem.
Sep 4, 2009 at 5:31 AM
  • 75,988 POSTS
If in fact you're getting spark from the coil that's if its a distributor type ignition system and nothing on the plug side best check the cap and rotor it has to go thru there before it gets to the plugs.
Sep 4, 2009 at 8:35 AM
