1996 Chevy S-10 crazy
COUNTRYBOY_08
  • 1996 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 270,000 MILES
My temp gauge is going up to almost 260 then it goes down nearly to 110 I wa wanting to know does it have more than one thermostat or what might b my problem
Friday, February 6th, 2009 AT 8:50 AM
FEESH13937
  • 12 POSTS
No there is only one thermostat, sounds like there is an air bubble in the cooling system. Check the radiator fluid level, and if it is full, then take the radiator cap off the radiator and start the truck. Let it run for about 5 or 10 min. And watch the filler hole where the radiator cap goes. Also keep an eye on the temp gage while you do this. It prob. Wont go up much because the cooling system isnt under presure. But keep an eye on the filler neck of the radiator as it should bubble a good bit if there is air in the system after running the truck for 5 or 10 min. If that does not work then try flushing the whole cooling system.
Thursday, February 12th, 2009 AT 1:54 AM
