blower motor replacement please?
MRAINO
where is the heater blower motor/fan and how do i replace it?
Dec 29, 2009 at 11:35 AM
OBXAUTOMEDIC
  • 3,711 POSTS
It is on the right side of engine compartment on firewall. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Dec 29, 2009 at 12:28 PM
OLHOMEY
need to change blower motor on truck and wondered how difficult this would be...i am mechanicaly inclined.
Jan 22, 2021 at 3:12 AM (Merged)
  • 75,988 POSTS
BLOWER MOTOR & FAN
Removal & Installation
Disconnect negative battery cable. Disconnect blower motor electrical connections. Remove Vehicle Control Module (VCM). Remove coolant recovery reservoir and blower motor cooling tube. Remove blower motor mounting screws.
Cut access cover along dotted lines. See Fig. 5 . Remove upper half of access cover, tearing remaining portion of access cover. Remove blower motor. Remove nut attaching blower fan to blower motor shaft. Remove fan.
To install, reverse removal procedure. After reinstalling cut-out portion of access cover, apply a bead of Black weatherstrip adhesive to cut and tear lines of access cover.
MACKOO
When I turn my heater fan on any setting I get a real loud grinding. Suspect the bearings in the fan motor. Can anyone give me the steps to replace the fan motor.
Thanks
  • 110,248 POSTS
1.Disconnect the negative battery cable. 2.Disconnect the PCM. 3.Remove the coolant reservoir. 4.Remove the rear coolant recovery reservoir mounting stud. 5.Disconnect the cooling tube from the blower motor. 6.Disconnect the electrical connector. 7.Remove the blower motor mounting bolts. 8.Remove the blower motor.
https://images.2carpros.com/forum/automotive_pictures/249084_blow_3.jpg
Fig. Blower motor removal-deluxe, outside air To install: 1.Install the blower motor. 2.Install the blower motor mounting bolts and tighten to 40 inch lbs. (4.5 Nm). 3.Connect the electrical connector (1). 4.Connect the cooling tube to the blower motor. 5.Install the rear coolant recovery reservoir mounting stud. 6.Install the coolant reservoir. 7.Install the PCM. 8.Connect the negative battery cable. Let me know if this helps. Joe
MACKOO
Thanks Joe. Great instructions and easy to do. Really appreciate the diagram.
  • 110,248 POSTS
first, thanks for the positive feed back. It's appreciated. Also, you are welcome and I'm glad it helped.
Let us know if you have questions in the future, and thanks for using 2carpros.com.
FIREFIGHTER1053
We are trying to install a blower motor. we need instructions to remove the old motor and replace with a new one.
DE772601
  • 123 POSTS
Hello well there are usually only 3 or 4 7milimeter screws that hold it in place and a plug with 2 wires on it that you just unplug and some of the new motors don't come with a new cage so you will have to switch it over if the new motor doesn't have one. Then just reinstall the the new motor the same way you took out the old one. If you have a problem please respond back.
E636L30
Heats up but hot air not distributed.
Good evening,
The blower motor is located under the hood, passenger side of the firewall. It has an electrical connector and five small screws that hold it into the housing.
Below are the procedures and a picture of the location for you to view.
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
REMOVE OR DISCONNECT
1. Negative battery cable.
2. VCM, if equipped.
3. Coolant recovery reservoir.
4. Blower motor cooling tube.
5. Screws.
6. Blower motor and fan assembly.
INSTALL OR CONNECT
1. Blower motor and fan assembly.
2. Screws.
3. Blower motor cooling tube.
4. Coolant recovery reservoir.
5. VCM, if equipped.
6. Negative battery cable.
- Check circuit operation.
