one way to watch the timing is to find tdc on compression stroke (but not necessary) make two marks, one on vibration dampner and one to the block or somewhere convienent. line them up and start the engine and watch with a timing light.
increase throttle and you should see the time advance more for higher rpms.
the ecu will start the timing and then the computer will take over, using crankshaft and camshaft sensor info for the best possible spark time.
Dec 27, 2008 at 1:05 PM
