1996 Chevy S-10 ABS System Computer
88,000 MILES • 4 CYL • 2WD • MANUAL
CNISWANDER
ABS light stays on. When it goes off, vehicle brakes unevenly. Code in engine computer indicates the ABS control unit malfunction. Where is ABS computer located? I would like to replace it with a used one. I checked all the Recall and SB's, but they don't seem to apply to my problem.
Thanks for your help.
May 31, 2010 at 3:22 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the electronic brake control module (EBCM) is mounted on the brake pressure modulator valve (BPMV) located at the left rear of the engine compartment
May 31, 2010 at 6:38 AM
