1996 Chevy S-10 ABS Light
72,000 MILES • 6 CYL • 2WD • AUTOMATIC
FMB1977
I have a 1996 Chevy S-10 with the ABS Light stuck on. Brakes seem to be working fine. I turn on the truck, all the lights come on, ABS goes off, but then comes back on and stays on. Any ideas? Thanks!
Sep 30, 2008 at 11:35 AM
SWILLIAMS
  • 597 POSTS
You have an ABS problem. You will need to pull the codes and see what you have. Could be anything from a simple broken sensor to a bad ABS unit.
Oct 2, 2008 at 4:18 PM
