1996 Chevy S-10 2 questions
118,216 MILES • 4 CYL • 2WD • MANUAL
STYLINS-10
When i go to start my truck in the morning, it turn it over and it sounds like the starter is spinning but not connecting with the engine. what could be wrong with it? Does a warning light come on when you are low on gas, or will you just run out.
Feb 12, 2008 at 9:18 AM
MASTERTECHTIM
  • 4,750 POSTS
your starter drive is bad on the starter so you need to install a new starter motor and there is no warning light, you will just run out of gas when the needle reads E.
Feb 12, 2008 at 9:30 AM
